19 years agoSetup an IRQ on a component
Hi ,
I made a "counter" component which I want to interrupt NIOS when reaching 8'h7. I also created a control register in which is bit IRDY (Interrupt Ready) I have 2 questions for my component : 1) How can I setup an IRQ for it ? ( like UART , its IRQ is 5. This info is in "System Contents" tab of "Altera SOPC Builder" ) 2) How can I make NIOS "connect" with my IRDY bit ? Thank you so much , Quan18 Replies
@Soin
Currently I'm trying to put an interrupt in my custom component. I have one question, in the interrupt signal (in my case its type is 'interrupt sender') properties, which Avalon MM that I suppose to assign? I still confused with the 'associateAddressablePoint' meaning... :( Could you explain it to me? I've tried to provide an Avalon MM slave consists of a 'write' and a 'writedata' signal. This Avalaon MM slave function is to let the CPU send a command to clear the interrupt bit. Then, I assign my interrupt signal in SOPC to this Avalon MM. However, the result is very strange... my program totally doesn't work, even it has hanged in the beginning.... :( Help me..please... - Altera_Forum
I don't really know what this setting is used for, but I always associate the interrupt sender to the MM interface used to clear the IRQ bit too, and never ran into any problem.
Your problem has probably another explanation. You could use SignalTap to check the status of you IRQ, see if it raised and check that it is properly cleared by the interrupt handler. - Altera_Forum
Hi everyone. I am also designing an counter with interrupt. This is my code:
And this code functions perfectly as wanted. But when want to add custom hardware in SOPC having trouble to select the interface and signal type. It shows an error Associated Addresablepoint out of range. :cry: Is it correct how i design the counter with interrupt? and how to add to SOPC builder? Any suggestions please. Thank you.//Write 1 to address 0 to start counter //Write 2 to address 0 to stop counter //Write 0 to address 0 to reset counter //Read address 1 to get count value module counter (clk, reset, address, chipselect, read, readdata, write, writedata,irq); input clk, reset, chipselect, read, write; input address; input writedata; output readdata; output irq; reg readdata; reg count; reg control; reg irq; //wire done; always @ (posedge clk) begin if (control==2'b01) count <= count + 1; else if (control==2'b00) count <= 0; else count <= count; end //assign irq=(count==32'd10)?1:0; always @ (posedge clk) begin if (count>=32'd1000000000) irq<=1; else irq<=0; end always @ (posedge clk) begin if (chipselect && write && (address==0)) control <= writedata; else if (chipselect && read && (address==1)) readdata <= count; else if (!chipselect) readdata <= 32'hZ; end endmodule - Altera_Forum
Hi Moganesh,
As Daixiwen said, to establish the interrupt in your component, besides providing interrupt signal, you also have to provide a register to store the IRQ state. Then in the interrupt signal properties, just associate the avalon MM to this register. I'm sorry I couldn't send the component file to you, because currently I can't access my workstation. Good luck - Altera_Forum
Hi fightingdreamer,
I did what you told like creating a register to store the interrupt and associated avalon mm slave to the register but still having the problem Here is the C-code:
I still having problem with the error showing Associated Addresablepoint out of range.//Write 1 to address 0 to start counter //Write 2 to address 0 to stop counter //Write 0 to address 0 to reset counter //Read address 1 to get count value module counter ( //Avalon MM clk, reset, address, chipselect, read, readdata, write, writedata, //Interrupt_handler irq,readdata_irq,writedata_irq,write_irq); input clk, reset, chipselect, read, write ; input write_irq ; input address; input writedata; output readdata; output irq; input writedata_irq; output readdata_irq; reg readdata; reg count; reg control; reg readdata_irq; reg irq; //wire irq; always @ (posedge clk) begin if (control==2'b01) count <= count + 1; else if (control==2'b00) count <= 0; else count <= count; end //assign irq=(count==32'd1000000000)?1:0; always @ (posedge clk) begin if (count>=32'd1000000000) irq<=1; else irq<=0; end always @( posedge clk) begin if (irq) begin readdata_irq<=1; end else if (write_irq && writedata_irq) begin readdata_irq<=0; end else readdata_irq<=0; end always @ (posedge clk) begin if (chipselect && write && (address==0)) control <= writedata; else if (chipselect && read && (address==1)) readdata <= count; else if (!chipselect) readdata <= 32'hZ; end endmodule - Altera_Forum
Actually just now i did not set the associated addressable interface parameter of the interrupt sender. That is what causing the errors. But I still having warning as follows:
Is the warning have to be considered or can be ignored?Warning: counter_0.irq: Interface has no signals Warning: counter_0.irq: Master has no read or write interface Warning: counter_0.interrupt_handler: readdata width must be in {8, 16, 32, 64, 128, 256, 512, 1024} for dynamic addressing Warning: counter_0.interrupt_handler: writedata width must be in {8, 16, 32, 64, 128, 256, 512, 1024} for dynamic addressing - Altera_Forum
Those warnings are rather strange. The first seems to say you didn't declare any signal in the irq interfare. Don't you have at least an irq signal? The second one seems to indicate that your irq interface is an Avalon master rather than an interrupt sender.
For the two others, your data bus should really be with a size that is a multiple of 8, even if you read/write only one bit. - Altera_Forum
Your data bus really needs to be 32bits for accesses from a NiosII cpu.
Otherwsie a 'bus width adapter' will be added to convert the 23bit master cycle from the Nios into multiple slave cycles (with the appropriate byte enables for writes).
