20 years agoSetup an IRQ on a component
Hi , I made a "counter" component which I want to interrupt NIOS when reaching 8'h7. I also created a control register in which is bit IRDY (Interrupt Ready) I have 2 questions fo...
15 years agoYour data bus really needs to be 32bits for accesses from a NiosII cpu.
Otherwsie a 'bus width adapter' will be added to convert the 23bit master cycle from the Nios into multiple slave cycles (with the appropriate byte enables for writes).
