20 years agoSetting breakpoints in SSRAM
I am due to receive a custom board soon which has just SSRAM and no SDRAM. We designed the board that way to reduce its complexity.
I am trying to use my 2c35 based Nios dev board to simulate this custom board to let me develop the software before the custom board arrives. When I change the linker set-up to put my software in SSRAM rather than SDRAM everthing works fine, except that if I set breakpoints in the IDE then the processor does not halt at the breakpoints: it just carries on. The map file shows that everything has moved correctly from the SDRAM to the SSRAM. Is there something different about SSRAM that stops me setting breakpoints? Do I need to do something like change the Nios CPU configuration to use hardware breakpoints instead of software? As soon as I change the linker script to build the software to run from SDRAM the breakpoints start working again! This is rather odd. Any help appreciated, Mike1 Reply
The breakpoints are working in SSRAM now, although I am not sure what I have changed. I think the main thing was to reboot my PC, rebuild the FPGA design, rebuild my ecos library and rebuild my project to make sure everything was fresh.
Mike
