16 years agoSetting a conditional breakpoint
Is there any way to set a conditional breakpoint in the NIOS IDE tool. I would like to set a breakpoint during a condition within an if statement. For example for(i = 0; i < 0x1ffffff; i++)...
16 years agoI have never tried setting a true conditional break point in Nios II IDE. However, a technique I have used before with many architectures is to simply add a NOP to your code with an IF statement on your condition. Then you can set a regular break point on the NOP.
So for your example, you could do something like:for(i = 0; i < 0x1ffffff; i++)
if(i == 0x1000000)
__asm__ volatile("nop"); <-- set break point here
