15 years agoSerial I/O runtime keeps crashing!
Hello, I have a Nios II system with two UARTs, both of which have worked perfectly fine for a while... Then I made a couple of unrelated changes to my Quartus design (outside the Nios system), and ev...
15 years agoFirst of all I'd suggest you connect your serial input to a "controllable" source, I mean any serial port which lets you decide when and what it transmits.
Although I don't know if this is feasible in your system, the straightforward setup would be connecting your UART to a PC serial port and using a Hyperterminal-like program to debug serial activity.
