16 years agosending packet like broadcast
Hello all, is possible to send packets in uClinux like broadcast ? I include code: ---------------------------- void udp_init_all(void) { // proved nastaveni ciloveho adresata soke...
16 years agoHi,
--- Quote Start --- When i use: ping -c 5 192.168.3.255 the command tries to send 5 packets, every packets i can see in wireshark, but the uclinux doesnot get answer. --- Quote End --- I think that you hit the command 'ping -c 5 192.168.3.255' from your Nios uClinux system. If so, please consider who will reply the answer. Can your network reply to the 'ping broadcast' ? MS Windows OS ignores such broadcasts and Linux can ignore those by setting 'echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts'. Kazu
