20 years agosection .text overlaps section .entry
Hello, I defined an internal ROM with 16kBytes (0x00c08000-0x00c0bfff) and an internal RAM with 2kBytes starting at address 0x00c02000. Small C library and Reduced Device Drviers are used. ...
20 years agoWhat did you specify as reset and exception addresses in SOPC builder? There should be 0x20 offset in the exception address. If you did have the offset then my suggestion is that regeneration cured your problem.
