20 years agoSearching Ethernet MAC with MII
Hi! I've a serious problem in finding a compatible MAC for Intel's LXT971ALE transceiver. The reason is simple: The transceiver has only a 4 bit datavector. But all MACs I found jus...
20 years ago --- Quote Start --- originally posted by fuerchth@Mar 27 2006, 02:25 PM hi!
i've a serious problem in finding a compatible mac for intel's lxt971ale transceiver.
the reason is simple:
the transceiver has only a 4 bit datavector. but all macs i found just provide 8 bit or more .....
the mac just has to provide mii.
can somebody help me out with a link or a name to search for?
tx andreas
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13821)
--- quote end ---
--- Quote End --- If you need internal core - try core from OPENCORES.ORG. Data width is 4 bits. If you are looking for external chip with MII interface try DM9000 from Davicom dm9000 link (http://www.davicom.com.tw/eng/products/dm9000.htm)
