19 years agosdram write fails for last 1K locations
Hi All, I have used sdram controller provided by SOPC builder(custom). the sdram part I am using is IS42S16400D. It is 8MB sdram. In the system library properties I have given .text, .rodata, ....
19 years ago --- Quote Start --- originally posted by shilpa v.prabhu@Mar 23 2007, 04:50 AM hi all,
i have used sdram controller provided by sopc builder(custom). the sdram part i am using is is42s16400d. it is 8mb sdram. in the system library properties i have given .text, .rodata, .rwdata, heap and stack as sdram. i am not able to read or write into first few locations of sdram, as this part of memory is used to store the code.this i can understand.
but i am also not able to write into last few locations(2k) of sdram. when i continuously write into these locations using a for loop, the data which i get after reading is wrong. when i do a write to single location and read back, then i am getting proper data. the same c code works for all other locations but not for last 2k locations. i am not able to understand this behaviour. i have tried this on simulation and on board. in both the cases continous write to last 2k locations is failing and if i perform write and read individually then it is passing.
please help me in debugging this issue. is this a timing issue? if so why is it failing only for last 2k locations?
thank you...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22452)
--- quote end ---
--- Quote End --- Hi, I'm using a similar SDRAM (IS42S16100C1), which has 16MBit. Somehow I kept in mind that .text, .rodata and .rwdata is stored at the beginning of the memory and heap and stack at the end of memory. Sorry, but I really can't remember where I read that and please, somebody correct me if I'm wrong. What I do is, I store .text, .rodata and .rwdata in the SDRAM and heap and stack in onchip_memory. I'm not totally done with testing that, but until now, this seems to work. Maybe try to declare 2K (or 4K) as onchip memory and use it for heap and stack.
