19 years ago
SDRAM vs. DDRAM Performance
Hi @all,
for a redesign i have to check which performance is better:
A 32bit SDRAM with the SOPC-Builder SDRAM Controller (Latency Aware SDRAM Controller Version 6.01)
or a 16bit DDRAM with the DDR-Controller (DDR-SDRAM Controller Version 3.40)
Both Systems will be clocked at 100MHz. The NIOS also. Therefore no extra clocks are generated by the Avalon-Logic. Make it sense to connect 2 Chips to the Nios to get a 32bit-Bus?
Which system has the better performance?
Thanx for your suggestions...
Bye
Marco
    That is interesting.
    If DDR 16Bit has a higher performance than SDRam 32Bit then i would like to know if anybody can tell me what the price is about comparing DDR and SDRam to have at the end the same memory size.
    Also has anybody any recomendations about the DDR design ?
    Where the pittfals are ? PCB, clock-phase, ....
    Maybe i should give DDR a try next time ...
    Regards.
    Michael
    --- Quote Start ---
    originally posted by mschmitt@Sep 21 2006, 04:36 PM
    that is interesting.
    if ddr 16bit has a higher performance than sdram 32bit then i would like to know if anybody can tell me what the price is about comparing ddr and sdram to have at the end the same memory size.
    also has anybody any recomendations about the ddr design ?
    where the pittfals are ? pcb, clock-phase, ....
    maybe i should give ddr a try next time ...
    regards.
    michael
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18389)
    --- quote end ---
    --- Quote End ---
    The easiest way is to use tje altera core that comes with the dev-board. I think you need a quartus subscription for that??
    Hi Stefaan,
    i already have 3 full subscription and already looked into the ip toolchain for DDR but i would like to know what kind of traps there are and where to have a special look after during the implementation of DDR.
    Michael
