21 years agoSDRAM verify failed in NIOS II IDE
I work under QII5.0. My SDRAM is Micron MT48LC2M32B2-7. I choose the "single Micron MT48LC2M32B2-7 chip" in the "presets" of sdram controller setup menu. My SDRAM base address is 0x00800000. Whe...
21 years agoI have solved my problem.
I use PLL and try to set the Phase Shift Value according to the datasheet. Finally, the sdram is running Ok.
