22 years agosdram transfer
We have tested block transfer in sdram with memcpy() fonction on développement kit stratix 1S10 NIOS II with uclinux v1.1. The frequency CPU is 50Mhz. We obtained with nois ii /s (no data cac...
22 years agoAnother thing you can do is, if you can identify a place where the data cache hurts you like this, you can use the "bit 31" trick to copy from/to noncacheable memory. This may help your II/f benchmarks converge with your II/s core benchmarks.
The "bit 31" trick is covered on page 7-7 of the Nios II Software Developer's Handbook. In short, only bits 30-0 of an address are actually driven onto the address bus. Bit 31 controls whether it goes through the data cache or not; if set, the data cache is bypassed. So all you have to do is pass (address | 0x80000000) to memcpy for each buffer you want uncached. Try your benchmarks with the cache bypassed for reads only, writes only, or both, and see what works best.
