12 years agoSDRAM signals managing
Hi, I'm using qsys to implement a system on Quartus II. I use a DE0-NANO board and I want to access the SDRAM. I want to access it from a Nios II (and also from the hardware design but it's anot...
12 years ago --- Quote Start --- Frequency doesn't seem to be critical: signals change at a rate of ~1MHz and I just need to be sure to capture every modification. --- Quote End --- Um, 1MHz is 1 million changes per second, so you are not going to read that via JTAG and get every transition! At 1MHz you will need a synchronous clock to capture the data changes, or you will need a faster clock, eg., 10MHz, and create a state machine that "looks" for changes in your 4-bit signal. --- Quote Start --- So (3) seems to interest me most (surely because I'm lazy!). --- Quote End --- I don't think it will work for 1MHz signal changes. --- Quote Start --- Only I still don't understand what an Avalon-MM is. Is this only an interface (to what?) or a complete component ? --- Quote End --- Avalon is just Altera's name for a bus interface protocol. There is a memory mapped definition (Avalon-MM) and a streaming definition (Avalon-ST). You need to read the Altera Qsys documentation, the Altera Avalon Specification, and look at some tutorials. Why don't you start by using SignalTap II with a 10MHz clock and capture a 1000 clock periods of data. That should correspond to 100 changes in your GPIO. Post a zoomed section so that we can see the logic changes, and then we can suggest interface options. Cheers, Dave
