12 years agoSDRAM signals managing
Hi, I'm using qsys to implement a system on Quartus II. I use a DE0-NANO board and I want to access the SDRAM. I want to access it from a Nios II (and also from the hardware design but it's anot...
12 years agoI have three new questions:
1-How to make the SDRAM available both for the software part (a Nios II cpu in a Qsys system) and the hardware part (a Quartus II design)? 2-How to tell Qsys that the program of the cpu should be stored in the internal FPGA memory and the data should be stored in the SDRAM? 3-I've downloaded this file: http://www.altera.com/products/ip/altera/ocore_sdr_sdram.html and a first problem is the address bus width. In the file it's 12-bit but in the first qsys system it was 13-bit. Thanks.
