20 years agoSDRAM problem
Hi, I have got a Cyclone dev kit (EP1C20) and i'm trying to get a design working that uses SDRAM to store some data. If I write the data and read it back it is valid but if there is a delay...
20 years agoHello GaryJS,
The described behaviour is typical for a low refresh rate. If you are using a ready reference design which comes with Nios II the system should be ok. Did you test the software with one of these reference designs? Regards, niosIIuser
