15 years agoSDRAM problem in SOPC builder
Hi, I get this warning message in SOPC builder saying: "Warning: cpu: The address range of the slaves connected to the NIOS 2 instruction master exceeds 28 bits. Attempts to call function acr...
12 years agoOn that note, we have been checking periodically at this site to see when the source code for the new tools (you referred to) might be available, but nothing has appeared so far.
http://www.altera.com/support/ip/processors/nios2/ide/ips-nios2-ide-tutorial.html Any rumors on when this can be made available? We use the source code to build a cross compiler configured specifically RTEMS RTOS. Thanks, Jeff
