20 years agoSDRAM PLL clock output
Has anyone ever got the following warning regarding the SDRAM PLL clock output: warning: pll "sys_pll1:sys_pll|altpll:altpll_component|pll" output port clk[2] feeds output pin "sdram_clk" via n...
20 years agoYou should check the pll chapter on the device handbook.
The input clk and output clk must feed to/from the same pll directly. If the input clock does not match the pll, it wont fit. If the output clock does not match, it will warn of the jitter.
