21 years agoSDRAM Pin Assignment issue
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Issue Resolved, used the first option from those mentioned below by freezy, thanks freezy http://forum.niosforum.com/work2/s...
21 years agoHi ppk031000,
Perhaps it's resulted from the conflicting of external tri-state bus between 2 memory devices on your board. Because I haven't used the board you mentioned, so it's just my speculation.I may give you two suggestions: 1)Perhaps it's because of your carelessness when you created your system, so reopen SOPCBuilder and the SDRAM component wizard.Now check the selection for "Share pins for via Tri-state Bridge" is checked or not, you should *check it* to avoid the bus-sharing result of SDRAM. 2)If the 1) cannot resolve your problem,Go to download or write by yourself a MUX module for your conflicted pins http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif Regards, Don
