22 years agoSDRAM Interface to SO-DIMM?
I'm planning a NiosII design and we need a pile of RAM but don't need the high bandwidth of SRAM. It's hard to find SDRAM chips in stock, given their commodity nature, and so I was looki...
22 years agoJesse,
Good points. This leads to another question: How would one go about setting up a project with a memory map (for the RAM area, at least) as follows: (Low Memory) vectors text segment data segment bss segment stack (fixed maximum size, grows down) heap (High memory) In this case, could the heap size be set at runtime? Failing that, could the upper heap limit be initialized to a point representing minimum-installed memory, which could then be moved up when more memory was detected? Just some thoughts.
