22 years agoSDRAM Interface to SO-DIMM?
I'm planning a NiosII design and we need a pile of RAM but don't need the high bandwidth of SRAM. It's hard to find SDRAM chips in stock, given their commodity nature, and so I was looki...
22 years ago(slightly off-topic)
Mike, if you're interested in I2C we've "ported" the opencores.org I2C. The component will be included with our uKit. The uKit has a connector that can be used for I2C (it has the neccessary pull-up resistors [1.5K], refrence power is available [3.3V] etc as per section 17.3 of the Phillips I2C spec). We have wired an EEPROM and a Real-Time clock to this connector and verified, under Linux, these device operate. The device drives are also included. mike
