20 years agoSDRam Controller is there a better one ?
Maybe somebody has a recomendation for me ... I use the sdram controller that is part of the sopc builder. The external sdram is 2 chips each 16 bit wide. Inside the FPGA cycloneII there...
20 years ago --- Quote Start --- originally posted by mschmitt@Sep 1 2006, 07:20 AM maybe somebody has a recomendation for me ...
i use the sdram controller that is part of the sopc builder.
the external sdram is 2 chips each 16 bit wide.
inside the fpga cycloneii there are several avalon masters.
niosii, 100mbit ethernet mac and some custom avalon masters.
currently i have a minimum of 7 avalon masters eqach accessing the sdram.
now it is abvious that the sdram is the bottle neck.
4 of the custom avalon masters needs to read or write 32bit from or to the sdram each 160 clocks. but the avalon switch fabric assert a waitrequest for a read of up to 60 clocks cycles. so 4 of these avalon masters could lead to an access problem.
has anybody a recomendation of a different sdram controller ?
out of my head i think i remember that the sdram controller that is part of the sopc builder was called "poor" and that there are better ones.
the avalon switch fabric i capable of setting some arbitrations.
i gave my own sopc modules higher numbers (2) than the nios2 (1) or the ethernet mac.
any recomendations how to speed up the sdram access ? fclock ist 64mhz. and quartus seems to have problems with incrementing fclk and fitting.
michael schmitt
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18013)
--- quote end ---
--- Quote End --- You say "I use the sdram controller that is part of the sopc builder". Are you talking about the SDRAM v3.4.0 DDR/DDR2 Altera SDRAM Megacore IP ? BR
