21 years ago
sdram clk driver source?
Hello:
Now I want to make a sdram daughtercard.But in my board the PLL external clk out pins have all
been used,so I have to use the internal PLL output clock signal to drive the sdram.I want to ask if
the internal clock signal is stable to drive the sdram?whar problems should I care for?
    Hi jigdo,
    > I want to ask if the internal clock signal is stable to drive the sdram?
    Depending on your design, you may have some jitter issues. However,
    I use a compensated output to drive my SDRAM clock via an I/O pin
    on one of my boards without any problems -- although the clock is
    only 50 MHz.
    You will have to consider any routing delay that will affect the phase
    relationship WRT your system clock and adjust as necessary in your
    PLL configuration.
    --Scott
