20 years agoSDRAM and speed gain
I want to build a system using SOPC builder that contains a SDRAM controller, that is accessed from a NIOS2 and a DMA controller, both running at 50MHz. If I have the SDRAM controller run at 100MHz, ...
20 years agoExcuse sirs,
let me make use of this question to take some doubts out. I didin't understand well the reply from jakos, so sorry if I'm being redundant. I use a 50Mhz Nios II Board Cyclone II. If I use PLLs in my Quartus projects can I improve the speed of my application? (For example wether I change the clock speed of all componentes (Nios II processor, extern memories,..) to 100Mhz). Was it what you mean, jakob? Thanks, Mendonca
