20 years agoSDRAM and speed gain
I want to build a system using SOPC builder that contains a SDRAM controller, that is accessed from a NIOS2 and a DMA controller, both running at 50MHz. If I have the SDRAM controller run at 100MHz, ...
20 years agoIt's hard to say whether it will be any faster or not. In general, the SDRAM controller isn't efficient, so adding domain-crossing logic probably will not help you out much. IT shouldn't be hard to run a simple test that reads all the locations and measures the timeusing a timer.
