13 years agoSDRAM and BSP settings
Hi everybody, I am using the SDRAM on the DE1 board with NIOS. The bad thing is that the download of the .elf file fails without further notices. The BSP settings on the linker tab are: .bss, .hea...
13 years agoHere is the message I get from the Nios command shell after using the command: nios2-download -g software/sw_nios2/sw_nios2.elf
Using cable "USB-Blaster [2-1.1]", device 1, instance 0x00 Processor is already paused Initializing CPU cache (if present) OK Downloaded 18KB in 0.1s Verifying 00800000 ( 0%) Verify failed between address 0x800000 and 0x803CD7 Leaving target processor paused The SDRAM base address is 0x800000. I tried to put the clock phase shift of the SDRAM to -1ns but it does not change anything.
