16 years agoSDRAM and Audio problem
I want to write some data in SDRAM with a FOR cicle and connect the audio codec MIC (in) to audio codec spk(out), the audio code segment is ok, the problem is when I add the write sdram function beca...
16 years agoI found the solution !!!!!!!!!!! my system has a timer and my C program doesn't have a handler for timer interrupt, If I don't use the timer I have to desactivate it on system properties.
Thanks for your help !!!!!!!!!!!!!!!!!!!!!!!
