16 years agoSDRAM and Audio problem
I want to write some data in SDRAM with a FOR cicle and connect the audio codec MIC (in) to audio codec spk(out), the audio code segment is ok, the problem is when I add the write sdram function beca...
16 years agoOk, thanks for the answer, I have the next configuration :
Read/write memory data is SDRAM http://www.pixilis.com/photos/55560/ But the problem is not solve !!!!! When I write for example 10 values the sound is ok, but when I write 1000 the sound is ok for seconds buts after it stops, why ???? If SDRAM doesn't containg program code ( or yes ??) .....
