16 years agoSDRAM and Audio problem
I want to write some data in SDRAM with a FOR cicle and connect the audio codec MIC (in) to audio codec spk(out), the audio code segment is ok, the problem is when I add the write sdram function beca...
16 years agoHi,
Have you selected data memory to SDRAM ? If you do that your data segment stored into SDRAM even while you select SRAM for your program code. Regards, Hardik Sheth
