20 years agoSDL Graphics library usage on NIOS II
Hi, Im trying to use SDL (Simple DirectMedia Layer) which is a cross-platform multimedia library designed to provide low level access to audio, keyboard, mouse, joystick, 3D hardware via OpenGL...
19 years ago --- Quote Start --- originally posted by drunken79@Feb 22 2007, 02:24 AM hi bigboss25,
sorry no french, just a french name and some "not polite" french words ;-)
you can grab my sdl sources from :
sdl for nios2 (http://drunken.intershit.com/sdl.tar.gz)
look in the file configure.nios for my ./configure options. after compiling, the library is in /src/.libs/ or in the directory you specified with --prefix.
some small example programms from :
example sdl programms (http://drunken.intershit.com/examples.tar.gz)
and a thread at gmane about uclinux and libsdl :
gmane sdl on uclinux (http://comments.gmane.org/gmane.comp.lib.sdl/4795)
the next few days i will try to use the nioswiki framebuffer with a separate external
sram chip. maybe this will speed up sdl on nios2!?
let me know if you need some 3d/opengl stuff for nios. i got picogl,tinygl and
some parts of libfixgl running.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21760)
--- quote end ---
--- Quote End --- Thanks a lot http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Your sources will be very useful for me. And yes, I think you really should use external SRAM to put frame buffer in it, otherwise you may overkill you memory bandwidth. Do you use a custom board or an eval board ? If you use 2C35 NIOS2 eval board, you should consider using the external SSRAM chip to store frame buffer datas. I will try graphics on nios2 in the next weeks and post about my experience. Thanks again. Regards.
