20 years agoSDL Graphics library usage on NIOS II
Hi, Im trying to use SDL (Simple DirectMedia Layer) which is a cross-platform multimedia library designed to provide low level access to audio, keyboard, mouse, joystick, 3D hardware via OpenGL...
19 years agoHi bigboss25,
sorry no french, just a french name and some "not polite" french words ;-) You can grab my SDL sources from : sdl for nios2 (http://drunken.intershit.com/sdl.tar.gz) look in the file CONFIGURE.NIOS for my ./configure options. After compiling, the library is in /src/.libs/ or in the directory you specified with --prefix. Some small example programms from : example sdl programms (http://drunken.intershit.com/examples.tar.gz) And a thread at gmane about uclinux and libsdl : gmane sdl on uclinux (http://comments.gmane.org/gmane.comp.lib.sdl/4795) The next few days i will try to use the Nioswiki Framebuffer with a separate external SRAM chip. Maybe this will speed up SDL on NIOS2!? Let me know if you need some 3D/Opengl stuff for Nios. I got PicoGL,TinyGL and some parts of libfixgl running.
