20 years agoSDL Graphics library usage on NIOS II
Hi, Im trying to use SDL (Simple DirectMedia Layer) which is a cross-platform multimedia library designed to provide low level access to audio, keyboard, mouse, joystick, 3D hardware via OpenGL...
19 years ago --- Quote Start --- originally posted by drunken79@Feb 21 2007, 11:29 AM hi,
i run successfuly sdl on nios2. using the vga framebuffer from nioswiki and
libsdl from blackfin uclinux. but it is real slooow with fbcon output and even slooooower
with nano-x output http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/biggrin.gif
libsdl from blackfin uclinux is stock libsdl with some map_shared/map_private patches in video_fbcon.c for dealing with nommu targets.
i guess the framebuffer from nioswiki is not realy the best choice for fast graphics , it lacks on burst memory interface and does not support dubble buffering in uclinux(?).
let me know if you need my libsdl sources.
claude
btw: does anybody know how to use the nios2 fpu in uclinux ? using soft float with
graphics make things even worse. glxgears with 0.5fps makes me dizzy http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21749)
--- quote end ---
--- Quote End --- Hi Claude, Yes , it would be very,very nice if you could provide me your libsdl sources. By the way, do you speak french ? If yes, it should be easier for us to talk http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Thanks a lot.
