20 years agoSDL Graphics library usage on NIOS II
Hi, Im trying to use SDL (Simple DirectMedia Layer) which is a cross-platform multimedia library designed to provide low level access to audio, keyboard, mouse, joystick, 3D hardware via OpenGL...
19 years agoHi,
i run successfuly SDL on Nios2. Using the VGA framebuffer from nioswiki and libsdl from blackfin uclinux. But it is real slooow with fbcon output and even slooooower with nano-X output http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Libsdl from blackfin uclinux is stock libsdl with some MAP_SHARED/MAP_PRIVATE patches in video_fbcon.c for dealing with nommu targets. I guess the framebuffer from nioswiki is not realy the best choice for fast graphics , it lacks on burst memory interface and does not support dubble buffering in uclinux(?). Let me know if you need my libsdl sources. Claude btw: does anybody know how to use the nios2 fpu in uclinux ? using soft float with graphics make things even worse. glxgears with 0.5fps makes me dizzy http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
