15 years agoSD Card Header Problem
I'm using an SD Card core in my SOPC builder system. In my Nios II IDE program I've included the associated header file. When I build the project I get the following error: /cygdrive/c/altera/...
15 years agoHi moeen,
Probably your projects includes somewhere stdbool.h header, which already has bool type and true/false defined If you can't fix it, you can try adding the following undefs just before including the header with the typedef # undef false # undef true # undef bool
