20 years agoSD card - DE2
Hi, Sorry for my english, I'm Brazilian. I have a Altera DE2 kit and I want to use SD Card on uCLinux. I have to make the same steps used for Compat Flash ? http://nioswiki.jot.com/w...
20 years ago --- Quote Start --- originally posted by jdhar@Jul 31 2006, 06:37 PM sorry for being away for a while guys... i have been extremely busy with contracting work, so i have been away from the linux scene for a while.
first off, that mmc driver i put out is definitely not complete... i tested it with mmc cards, so i'm not sure how it works using sd cards. and hippo, please use the updated link for the svn server, the dynalias one has been out for a long time.
http://via.fps-tech.org/svn/ (http://via.fps-tech.org/svn/)
also, i stopped creating patch files for the mmc driver since most ppl weren't using them. most ppl just wanted the whole kernel tree with the driver included, so you are better off grabbing the whole kernel source from:
http://via.fps-tech.org/snapshots/uclinux/kernel/ (http://via.fps-tech.org/snapshots/uclinux/kernel/)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17295)
--- quote end ---
--- Quote End --- hello, i need to use this sd support and neither way works: patch (you said to be broken) and downloading this already patched kernel if you can point out where to read so i can go through this goal http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif i have a DE2 board, and need to use SD card. i work with isaac and iḿ in charge to make a uClinux ffrom scratch to work on it. up to now, just a generic build works and the result cant boot properly http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif it says cant find root. thanks in advance http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif matheus
