20 years agoSD card - DE2
Hi, Sorry for my english, I'm Brazilian. I have a Altera DE2 kit and I want to use SD Card on uCLinux. I have to make the same steps used for Compat Flash ? http://nioswiki.jot.com/w...
20 years agoSorry for being away for a while guys... I have been extremely busy with contracting work, so I have been away from the linux scene for a while.
First off, that MMC driver I put out is definitely not complete... I tested it with MMC cards, so I'm not sure how it works using SD cards. And hippo, please use the updated link for the SVN server, the dynalias one has been out for a long time. http://via.fps-tech.org/svn/ (http://via.fps-tech.org/svn/) Also, I stopped creating patch files for the MMC driver since most ppl weren't using them. Most ppl just wanted the whole kernel tree with the driver included, so you are better off grabbing the whole kernel source from: http://via.fps-tech.org/snapshots/uclinux/kernel/ (http://via.fps-tech.org/snapshots/uclinux/kernel/)
