20 years agoschematic for the nios2 eval board
Where can I get the schematic for the NIOS2 board. I have the CD's, but the schematic is not on them, at least I can't find them. Also, I downloaded the .zip file and the build scrip...
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- I, too, have been looking for this sort of information, but have had less luck that you, apparently. Do you mind sharing a specific URL?[/b] --- Quote End --- Mine was found at: C:\altera\kits\nios2_51\documents\nios_cyclone_1c12_eval\nios2_evaluation_1c12_board_schematic.pdf Or you could perform a search in your HD for the file named: nios2_evaluation_1c12_board_schematic.pdf Good luck!
