21 years agoscheduling policy
We're running uClinux based on linux version 2.6.x under the Nios II IDE v1.0.0 build 393. In experimenting with POSIX threads, I've been attempting to activate timeslicing for an app...
21 years agoHi Halfdome,
Can you try the following code? struct sched_param schp;
* set the process to realtime privs
memset(&schp, 0, sizeof(schp));
schp.sched_priority = sched_get_priority_max(SCHED_FIFO);
if (sched_setscheduler(0, SCHED_FIFO, &schp) != 0) {
perror("sched_setscheduler");
exit(1);
} Regards, wentao
