19 years agoschedule problem
hi all, i write a kernel module, when i insmod it, the following is output: bad: scheduling while atomic! Stack from 081dff8c:<0> <0> ffffe000<0> 08189464<0> 081b0e94<0> 026...
19 years agoIt may be out of memory,or corrupted.
How do you build the module? What is your build enviroment ? Did you strip out unnecessary? You may use printk() to debug.
