19 years agoschedule problem
hi all,
i write a kernel module, when i insmod it, the following is output: bad: scheduling while atomic! Stack from 081dff8c:<0> <0> ffffe000<0> 08189464<0> 081b0e94<0> 02625a00<0> 00000000<0> 00000000<0> 00000000<0> 00000000<0> <0> 00000000<0> 00000000<0> 00000000<0> 00000000<0> 08fc0428<0> 00000000<0> 00000001<0> 00000002<0> <0> 08fc04d8<0> ffffe000<0> 00000000<0> 0800305c<0> 0800307c<0> 080001a0<0> 081fc4e0<0> 081e0790<0> <0> 081e0298<0> 081f45bc<0> 08800000<0> 08006860<0> 08000100<0> Call Trace:<0> where it may be wrong? and how can i trace the kernel routine? in x86 platform, i can use kgdb to debug it, now in nios2, how should i do? thanks for your help.3 Replies
It may be out of memory,or corrupted.
How do you build the module? What is your build enviroment ? Did you strip out unnecessary? You may use printk() to debug. - Altera_Forum
thanks for your care,
my build enviroment is correct, in nios2 sdk enviroment. but i don't know where i put the printk(), these messages is out of schedule(), i don't know which task cause this happen, so i need trace the routine, like kgdb does. can you help me? - Altera_Forum
You may try a simple hello module first to verify your build enviroment.
But I would perfer Linux enviroment to build uClinux.
