21 years agoR/W Filesystem?
I'm currently running the stock FS, built following the instructions in the Getting Started manual. Is there any quick way to make this FS read/write? Changing the kernel command line str...
21 years agoI had the same problem, but it was solved when I erased the flash...
Can you verify that the zone you erased is actually empty (all 1's) ? pod
