21 years agoR/W Filesystem?
I'm currently running the stock FS, built following the instructions in the Getting Started manual. Is there any quick way to make this FS read/write? Changing the kernel command line str...
21 years agomount -t jffs2 /dev/mtdblock0 /temp/flashmount -n
should be fine. That partition shall be erased first, otherwise you may get a long train of messages.
