21 years agoR/W Filesystem?
I'm currently running the stock FS, built following the instructions in the Getting Started manual. Is there any quick way to make this FS read/write? Changing the kernel command line str...
21 years agoHi Ryan,
CONFIG_MTD_BLOCK should be defined. > I guess I need to do some kind of formatting? You should be able to mount a "blank: (erased) partition without any problems. Amd/Fujitsu Extended Query Table at 0x0040
Microtronix map: CFI does not contain boot bank location. Assuming top. What device is on your board? And where is your partition located? If you don't actually have a top boot device and your partition is at the top of the device you'll see erase/program errors at the offsets that are assumed to be boot sectors. Regards, --Scott
