13 years agoRunning uClinux on the DE2-115
Hi all, Have anyone successfully run the uClinux on a DE2-115? I was able to get the uClinux version 3.1 to run on the NEEK kit and would like to try it on the DE2-115, but run into "Pausing ta...
13 years agoYou have to give me/people more to go on than that... *.dts file, Boot messages. Are you sure your Quartus design is correct?
You say you can assign an IP address - so, can you successfully "ping?" I haven't ever used "mii-tool" but I'd suggest, once again, that you post your command, and output (maybe -v verbose output will help). THAT SAID, I googled your error and found that "mii-tool" is depreciated maybe -- "ethtool" is the way to go.
