13 years agoRunning uClinux on the DE2-115
Hi all, Have anyone successfully run the uClinux on a DE2-115? I was able to get the uClinux version 3.1 to run on the NEEK kit and would like to try it on the DE2-115, but run into "Pausing ta...
13 years agoI done the process and i finally able to set the ip address and set the eth0 to up and down
but after that i set the IP address i get the below message libphy: Trying 1000/FULL, and it's like it stop in this step and also when i try to use "mii-tool" i get the below error message "SIOCGMIIPHY on 'eth0' failed: Operation not supported no MII interfaces found" Please give me some suggestion
