13 years agoRunning uClinux on the DE2-115
Hi all, Have anyone successfully run the uClinux on a DE2-115? I was able to get the uClinux version 3.1 to run on the NEEK kit and would like to try it on the DE2-115, but run into "Pausing ta...
13 years agosorry this post was accedently deleted: (should be post# 16)
ok so i tried with the 0x0100000 link offset ... now when booting uclinux it hangs with " turn off boot console early0 " what does it mean? Edit: ok got it to work by enabling "SERIAL_ALTERA_UART_CONSOLE" in kernel settings, uclinux booted !!! thank you every1 here who helped!!!! EDIT2: u can find more information about linux config for: 1-JTAG UART or Serial UART 2-link offset calculation in the following link: www . alterawiki . com / wiki / Linux Config
