13 years agoRunning uClinux on the DE2-115
Hi all, Have anyone successfully run the uClinux on a DE2-115? I was able to get the uClinux version 3.1 to run on the NEEK kit and would like to try it on the DE2-115, but run into "Pausing ta...
13 years agovdvoznyuk:
It was critical for me, I *had* to use make 3.81, with 3.82 it was a nightmare, lots of "errors" in Makefiles and such. With 3.81 it worked directly. sam3oun: You should use 0x00000000 as start for SDRAM, correct. There is a way of calculating the link address offset, i think it is supposed to be 2/3 of the SDRAM size. However, I used 0x01000000, which worked perfectly.
