13 years agoRunning uClinux on the DE2-115
Hi all, Have anyone successfully run the uClinux on a DE2-115? I was able to get the uClinux version 3.1 to run on the NEEK kit and would like to try it on the DE2-115, but run into "Pausing ta...
13 years agoHello!
Ok. My main problem is that after nios2-download nothing happens. And so, I don't know what's the problem. zImage is successfully downloaded, As terminal i tried to use both nios2-terminal and uart terminal. Do you use qsys or sopcbuilder and device tree or not? Maybe someone knows, how uClinux can boot if I download only zImage.initramfs.gz? Is u-boot integrated into it? I use sdram for this image. Should reset address point to base address of sdram in this case?
