20 years agorunning sw in SDRAM
Hello, I want to use SDRAM for a small set of functions, toghether with big chunks of data. The rest of the software runs from SRAM. I verfied the correct working of the SDRAM, the instruc...
20 years ago....or use the memtest example software template, running out of SRAM or onchip memory, to really slam the SDRAM. It will even make use of a DMA (which is latency aware), if you have one in your system.
Cheers, - slacker
