12 years agoRunning separate C code on separate core in NIOS Multi-core system
Hello, I have done projects on NIOS II core for single processor system. Now, I need to learn and implement a multi-core system. I have very basic doubts for a multi-core system: ...
12 years ago --- Quote Start --- Hi, What should i do for this case?? --- Quote End --- Post a .zip with your subsystem .qsys and toplevel .qsys --- Quote Start --- 2. I want to know the difference betwn Avalon MM Data Master Port and Avalon MM Instruction Master Port. Which out of these should be connected to Onchip Memory, JTAG UART, custom block, performance counter and WHY ??? --- Quote End --- The instruction master is used for fetching instructions. The data master is used for performing data operations (reading/writing variables your program uses, reading/writing peripheral control registers). Connect the instruction master to the memory where your program is located. Connect the data master to (basically) everything including the program memory.
