12 years agoRunning Quartus 13.0sp1 Triple Speed Ethernet IP on uClinux
Hi, I have had no luck getting the Ethernet connection working and am hoping someone could provide some guidance. I have a Cyclone V GX development board running uClinux but I would like to enh...
12 years agoHi Kazu,
Thank you very much for your respond. I updated the PC gateway IP with 192.168.0.1, but fail to update the uClinux gateway. When I executed command "route add default gw 192.168.0.1" in uClinux, it gives me "route: SIOCADDRT: Network is unreachable". I am using the "trunk" branch uClinux ver.3.7 and the latest sopc2dts for device tree. Is the following dts output correct? tse_mac: ethernet@0x14003200 { Compatible ="ALTR,tse-13.0", "ALTR,tse-1.0"; reg = < 0x14004000 0x00000400 0x14003300 0x00000040 0x14003200 0x00000040 0x14006000 0x00002000 >; reg-names = "control_port", "rx_csr", "tx_csr", "s1"; interrupt-partent = < &myNios2 >; interrupts = < 3 4 >; ALTR, rx-fifo-depth = < 2048 >; ALTR, tx-fifo-depth = < 2048 >; address-bits = < 48 >; max=frame-size = < 1518 >; local-mac-address = [ 00 07 ed 21 00 06 ]; phy-mode = "rgmii' ALTR,mii-id = < 0 >; ALTR,phy-addr = < 0 >; //I manually added into the dts. To my knowledge, it doesn't make a difference to have this line or not. }; Thanks, Yeung
